按月统计查询之SQL语句
2013年8月26日 22:17 本文热度 9305
数据表Order.dbo结构:
OrderNo varchar(10), ---单号
GetDate Varchar(10), ---日期
Sales Varchar(10), ---员
ItemNo Varchar(20), ---产品号
Amount Smallint ---金额
数据记录如下:
001 2004-01-01 ABC A001 1000
001 2004-01-15 QQQ A001 5000
002 2004-02-01 ABC A001 2000
003 2004-03-01 ABC A001 3000
004 2004-06-01 ABC A001 6000
要求输入欲查询的年度条件如:2004,得到按月份统计的如下结果:
Slaes 200401 200402 200403 200404 200405 200406 200407 200408 200409 200410 200411
ABC 1000 2000 3000 6000
QQQ 5000
第一种答案:
declare @sql varchar(8000)
set @sql = 'select Sales'
select @sql = @sql + ',sum(case left(GetDate,7) when '''+left(GetDate,7)+''' then Amount end) ['+ replace(left(GetDate,7),'-','')+']'
from (select distinct left(GetDate,7) as GetDate from test) as a
select @sql = @sql+' from test group by Sales'
print @sql
exec(@sql)
第二种答案:
SQL语句:
select
sales as '业务员',
sum(case when month(getdatetime)=1 then amount end) as '1月份总额',
sum(case when month(getdatetime)=2 then amount end) as '2月份总额',
sum(case when month(getdatetime)=3 then amount end) as '3月份总额',
sum(case when month(getdatetime)=4 then amount end) as '4月份总额',
sum(case when month(getdatetime)=5 then amount end) as '5月份总额',
sum(case when month(getdatetime)=6 then amount end) as '6月份总额',
sum(case when month(getdatetime)=7 then amount end) as '7月份总额',
sum(case when month(getdatetime)=8 then amount end) as '8月份总额',
sum(case when month(getdatetime)=9 then amount end) as '9月份总额',
sum(case when month(getdatetime)=10 then amount end) as '10月份总额',
sum(case when month(getdatetime)=11 then amount end) as '11月份总额',
sum(case when month(getdatetime)=12 then amount end) as '12月份总额'
from you_table group by sales
--存储过程
create procedure sp_ordertable
@Year int
as
select
sales as '业务员',
from lpy_ordertable where year(getdatetime)=@year group by sales
exec sp_ordertable 2004
业务员 1月份总额 2月份总额 3月份总额 4月份总额 5月份总额 6月份总额 7月份总额 8月份总额 9月份总额 10月份总额 11月份总额 12月份总额
abc 1000 2000 3000 NULL NULL 6000 NULL NULL NULL NULL NULL NULL
qqq 5000 NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL NULL
(所影响的行数为 2 行)
该文章在 2013/8/26 22:17:15 编辑过
全部评论1
2013年8月26日 22:19
方法一:这种方法列名是固定的。
select 名称,
sum(case when substring(convert(varchar(7),日期,120),6,2)='09' then 出售数量 else 0 end) as '9月',
sum(case when substring(convert(varchar(7),日期,120),6,2)='10' then 出售数量 else 0 end) as '10月'
from 表
group by 名称
方法二:这种方法虽然麻烦一些,但是支持列名不确定的情况。
declare @sql varchar(2000)
declare @mon varchar(2)
set @sql = 'select 名称'
select @sql = @sql + ',sum(case mon  when '''+mon+''' then 出售数量 end) ['+mon+'月]'
from (select distinct substring(convert(varchar(7),日期,120),6,2) mon from 表) as a
select @sql = @sql+' from 表 group by 名称'
exec(@sql)
该评论在 2013/8/26 22:19:17 编辑过
