C#.Net 根据IP地址解析所属的国家省市县代码
2026年9月17日 2:55 本文热度 3450
using System;
using System.Web;
using System.Net;
using System.Text;
public class IpLocationHandler : IHttpHandler
    // 核心函数:传入IP,返回【国家+省+市+县】,内网直接返回 局域网IP地址
    public string getIPAddress(string ip)
        if (IsLocalIp(ip))
            return "局域网IP地址";
        string url = string.Format("https://ip9.com.cn/get?ip={0}", HttpUtility.UrlEncode(ip));
        HttpWebRequest request = null;
        HttpWebResponse response = null;
        try
            // 兼容 .NET4.0,使用数字常量开启TLS1.2,解决未能创建SSL/TLS安全通道
            ServicePointManager.SecurityProtocol = (SecurityProtocolType)3072;
            request = (HttpWebRequest)WebRequest.Create(url);
            request.Timeout = 3000;      //3秒超时
            request.ReadWriteTimeout = 3000;
            request.Method = "GET";
            request.UserAgent = "Mozilla/5.0 (Windows NT 10.0; Win64; x64)";
            response = (HttpWebResponse)request.GetResponse();
            using (var sr = new System.IO.StreamReader(response.GetResponseStream(), Encoding.UTF8))
                string respText = sr.ReadToEnd();
                string country = GetJsonValue(respText, "country");
                string province = GetJsonValue(respText, "province");
                string city = GetJsonValue(respText, "city");
                string district = GetJsonValue(respText, "district");
                StringBuilder sb = new StringBuilder();
                if (!string.IsNullOrEmpty(country)) sb.Append(country);
                if (!string.IsNullOrEmpty(province)) sb.Append(province);
                if (!string.IsNullOrEmpty(city)) sb.Append(city);
                if (!string.IsNullOrEmpty(district)) sb.Append(district);
                return sb.ToString().Trim();
        catch (Exception ex)
            //调试模式:返回错误信息,上线改为 return "未知地址";
            return string.Format("【ERROR】{0}", ex.ToString());
        finally
            if (response != null) response.Close();
            if (request != null) request.Abort();
    /// <summary>
    /// 判断内网IP
    /// </summary>
    private bool IsLocalIp(string ipStr)
        IPAddress ip;
        if (!IPAddress.TryParse(ipStr, out ip))
            return false;
        byte[] ipBytes = ip.GetAddressBytes();
        //10.0.0.0/8
        if (ipBytes[0] == 10) return true;
        //172.16.0.0/12
        if (ipBytes[0] == 172 && ipBytes[1] >= 16 && ipBytes[1] <= 31) return true;
        //192.168.0.0/16
        if (ipBytes[0] == 192 && ipBytes[1] == 168) return true;
        //回环地址
        if (IPAddress.IsLoopback(ip)) return true;
        return false;
    /// <summary>
    /// 简易提取JSON字段,无第三方依赖
    /// </summary>
    private string GetJsonValue(string json, string key)
        string searchKey = string.Format("\"{0}\":", key);
        int idx = json.IndexOf(searchKey);
        if (idx < 0) return "";
        int start = idx + searchKey.Length;
        if (start >= json.Length) return "";
        char startChar = json[start];
        int end;
        if (startChar == '"')
            start++;
            end = json.IndexOf('"', start);
        else
            end = json.IndexOf(',', start);
            if (end < 0) end = json.IndexOf('}', start);
        if (end < 0 || end > json.Length) return "";
        return json.Substring(start, end - start).Trim();
    public void ProcessRequest(HttpContext context)
        context.Response.ContentType = "text/plain";
        string ip = context.Request.QueryString["ip"] ?? "";
        string location = getIPAddress(ip);
        context.Response.Write(location);
    public bool IsReusable
        get { return true; }
补充说明
  1. 数字 3072 = TLS1.2,这个写法兼容 .NET Framework4.0,不会报枚举不存在编译错误;
  2. 服务器操作系统(Windows Server 2008 R2)需要系统层面支持 TLS1.2,如果系统没打补丁,就算代码写了也会继续报 SSL 通道错误,需要安装 Windows 系统补丁。
  3. 调试完成上线时,把 catch 里面代码替换为:
    return "未知地址";
该文章在 2026/9/17 11:11:55 编辑过
