纯 CSS 使用 column 属性实现瀑布流布局
2025年8月4日 10:35 本文热度 5126
什么是瀑布流?
看一张图,以下图片来源于花瓣网截图:
如上图所示,瀑布流就是让内容按列显示,自动填充空白。
使用 column 实现瀑布流
源码:
<div class="masonry">
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
</div>
<style>
:root{
  --item-bg-1: #ff4757;
  --item-bg-2: #cea442;
  --item-bg-3: #18005f;
  --counter-bg: #dedede;
.masonry {
  column-count: 1;
  column-gap: 20px;
  /* 重置计数器 */
  counter-reset: item-counter;
/* 使用媒体查询处理不同视口宽度显示不同列数 */
@media screen and (min-width: 400px) {
  .masonry {
    column-count: 2;
@media screen and (min-width: 600px) {
  .masonry {
    column-count: 3;
@media screen and (min-width: 800px) {
  .masonry {
    column-count: 4;
@media screen and (min-width: 1200px) {
  .masonry {
    column-count: 5;
.item {
  box-sizing: border-box;
  break-inside: avoid;
  margin: 0 0 20px;
  /* css 计数器 */
  counter-increment: item-counter;
  position: relative;
/* 显示计数器 */
.item:before {
  position: absolute;
  top: 0;
  left: 0;
  padding: 8px 0;
  min-width: 2em;
  text-align: center;
  background-color: var(--counter-bg);
  content: counter(item-counter);
/* 给 item 设置不同的高度和背景色 */
.item:nth-child(7n+1) {
  height: 151px;
  background-color: var(--item-bg-1);
.item:nth-child(7n+2) {
  height: 187px;
  background-color: var(--item-bg-2);
.item:nth-child(7n+3) {
  height: 289px;
  background-color: var(--item-bg-3);
.item:nth-child(7n+4) {
  height: 123px;
.item:nth-child(7n+5) {
  height: 234px;
.item:nth-child(7n+6) {
  height: 188px;
.item:nth-child(7n+7) {
  height: 149px;
</style>
效果:
视口宽度大于 1200px 时,显示 5 列:
视口宽度在 600px-800px 之间时,显示 3 列:
column 相关属性
column-count
column-count 声明显示多少列。默认值为 auto,由浏览器自己决定。
column-fill
column-fill 控制元素内容分成列时的平衡方式。有效值:auto(按顺序填充列)、balance(仅最后一页内容平均分配到各列)、balance-all(全部分页内容平均分配到各列)。
column-gap
column-gap 设置列间隔。默认值 normal 表示列间距占用 1em 宽度。
column-rule
column-rule 简写属性,包含 column-rule-width、column-rule-style 和 column-rule-color 。
column-rule-width 设置线条宽度。
column-rule-style 与 border-style 一样,支持值:none 、 hidden 、 dotted 、 dashed 、 solid 、 double 、 groove 、 ridge 、 inset 、 outset。
column-rule-color 设置线条颜色。
column-span
column-span 设置子元素是否跨列显示。有效值:none(不跨列)、all(跨列)。
column-width
column-width 设置列的宽度。浏览器会自动调整宽度大小,如果设置的宽度连两列都放不下,会自动变为一列显示(如图三)。
columns
columns 简写属性,可组合设置 column-width 和 column-count 属性。
grid 实现瀑布流
源码:
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
  <div class="item">
  </div>
</div>
<style>
:root{
.masonry {
  display: grid;
  grid-gap: 20px;
  grid-auto-flow: dense row;
  grid-template-columns: repeat(9, 1fr);
  grid-auto-rows: minmax(50px, auto);
  /* 重置计数器 */
.item {
  /* css 计数器 */
  position: relative;
/* 显示计数器 */
.item:before {
  position: absolute;
  top: 0;
  left: 0;
  padding: 8px 0;
  min-width: 2em;
  text-align: center;
  grid-row: 1 / 4;
  grid-row: 1 / 3;
  grid-row: 1 / 4;
  grid-row: 4 / 7;
  grid-row: 3 / 9;
  grid-row: 4 / 8;
  grid-row: 7 / 11;
</style>
效果:
写在最后
在多列布局方面 column 属性相比于 flex 和 grid 而言,显得更有优势。
虽说 grid 也能做出瀑布流效果,不过需要指定每个网格单元的占用大小。
column 虽然不用控制每个子项的大小,但它的子元素排列顺序是从上到下排列,并不是从左往右,这种情况如果数据存在分页加载时候,就会出现内容重新排列导致内容闪动。
在瀑布流布局这个需求场景下,CSS 多多少少还是有点弱鸡~~必要时候还是只有祭出 JS 。
其他相关资料:
break-* 控制多列布局如何中断换列: https://developer.mozilla.org/zh-CN/docs/Web/CSS/break-inside
​转自https://www.cnblogs.com/linx/p/18867615
该文章在 2025/8/4 10:35:44 编辑过
