C#实现混合P2P点对点直接连接方案(TCP + UDP),如果TCP连接失败则改用UDP连接
2025年6月23日 17:25 本文热度 11149
下面是一个整合了TCP和UDP打洞技术的完整P2P解决方案。该方案优先尝试TCP连接,如果失败则自动回退到UDP连接,最大程度提高P2P连接成功率。
整合后的P2P协调服务器方案
下面提供完整的TCP/UDP混合P2P协调服务器方案代码,该服务器同时处理TCP和UDP请求,支持双协议P2P连接:
1. 协调服务器 (HybridCoordinatorServer.cs)
using System;
using System.Net;
using System.Net.Sockets;
using System.Text;
using System.Threading;
using System.IO;
class HybridCoordinatorServer
    private const int ServerPort = 11000;
    private TcpListener _tcpListener;
    private UdpClient _udpServer;
    private readonly Dictionary<string, IPEndPoint> _tcpEndpoints = new();
    private readonly Dictionary<string, IPEndPoint> _udpEndpoints = new();
    private readonly Dictionary<string, TcpClient> _tcpConnections = new();
    private readonly object _lock = new object();
    private bool _isRunning = true;
    public HybridCoordinatorServer()
        try
            _tcpListener = new TcpListener(IPAddress.Any, ServerPort);
            _udpServer = new UdpClient(ServerPort);
            Console.WriteLine($"混合协调服务器启动,监听端口: {ServerPort}");
        catch (Exception ex)
            Console.WriteLine($"服务器初始化失败: {ex.Message}");
            Environment.Exit(1);
    public void Start()
        // 启动TCP监听线程
        new Thread(ListenTcp).Start();
        // 启动UDP监听线程
        new Thread(ListenUdp).Start();
        // 启动心跳检测线程
        new Thread(HeartbeatMonitor).Start();
        Console.WriteLine("服务器运行中. 按任意键停止...");
        Console.ReadKey();
        Stop();
    private void ListenTcp()
        try
            _tcpListener.Start();
            Console.WriteLine("TCP监听已启动");
            while (_isRunning)
                TcpClient client = _tcpListener.AcceptTcpClient();
                new Thread(() => HandleTcpClient(client)).Start();
            if (_isRunning) Console.WriteLine($"TCP监听错误: {ex.Message}");
    private void HandleTcpClient(TcpClient client)
        string clientId = null;
        try
            NetworkStream stream = client.GetStream();
            byte[] buffer = new byte[1024];
            int bytesRead = stream.Read(buffer, 0, buffer.Length);
            if (bytesRead == 0) return;
            string message = Encoding.ASCII.GetString(buffer, 0, bytesRead);
            string[] parts = message.Split(':');
            if (parts.Length < 2) return;
            string command = parts[0];
            clientId = parts[1];
            var clientEP = (IPEndPoint)client.Client.RemoteEndPoint;
            Console.WriteLine($"[TCP] {clientId} 连接: {clientEP}");
            lock (_lock)
                if (command == "REGISTER")
                    _tcpEndpoints[clientId] = clientEP;
                    _tcpConnections[clientId] = client;
                    Console.WriteLine($"[注册] TCP: {clientId} -> {clientEP}");
                    // 响应客户端
                    SendTcpResponse(client, "REGISTERED");
                    // 请求客户端UDP端点
                    SendTcpResponse(client, "REQUEST_UDP");
                else if (command == "CONNECT" && parts.Length > 2)
                    string targetId = parts[2];
                    Console.WriteLine($"[连接请求] {clientId} -> {targetId}");
                    HandleConnectionRequest(clientId, targetId);
            // 处理后续消息
            while (_isRunning)
                if (bytesRead == 0) break;
                command = parts[0];
                else if (command == "UDP_PORT")
                    if (parts.Length > 2 && int.TryParse(parts[2], out int udpPort))
                        lock (_lock)
                            var udpEp = new IPEndPoint(clientEP.Address, udpPort);
                            _udpEndpoints[clientId] = udpEp;
                            Console.WriteLine($"[注册] UDP: {clientId} -> {udpEp}");
            Console.WriteLine($"处理TCP客户端错误: {ex.Message}");
        finally
            if (clientId != null)
                lock (_lock)
                    _tcpConnections.Remove(clientId);
                    _tcpEndpoints.Remove(clientId);
                    _udpEndpoints.Remove(clientId);
            client.Close();
    private void ListenUdp()
        try
            Console.WriteLine("UDP监听已启动");
            while (_isRunning)
                IPEndPoint remoteEP = new IPEndPoint(IPAddress.Any, 0);
                byte[] data = _udpServer.Receive(ref remoteEP);
                string message = Encoding.ASCII.GetString(data);
                if (parts.Length < 2) continue;
                string clientId = parts[1];
                lock (_lock)
                    if (command == "REGISTER_UDP")
                        _udpEndpoints[clientId] = remoteEP;
                        Console.WriteLine($"[注册] UDP: {clientId} -> {remoteEP}");
                    else if (command == "HEARTBEAT")
                        // 更新UDP端点(NAT可能改变端口)
                        SendUdpResponse(remoteEP, "HEARTBEAT_ACK");
            if (_isRunning) Console.WriteLine($"UDP监听错误: {ex.Message}");
    private void HeartbeatMonitor()
        while (_isRunning)
            Thread.Sleep(30000); // 每30秒检查一次
            lock (_lock)
                Console.WriteLine($"[状态] 客户端数: {_tcpConnections.Count} TCP, {_udpEndpoints.Count} UDP");
                // 检测不活跃的TCP客户端
                List<string> tcpToRemove = new List<string>();
                foreach (var kvp in _tcpConnections)
                    if (!IsTcpClientConnected(kvp.Value))
                        tcpToRemove.Add(kvp.Key);
                foreach (string clientId in tcpToRemove)
                    Console.WriteLine($"[清理] 移除不活跃TCP客户端: {clientId}");
    private bool IsTcpClientConnected(TcpClient client)
        try
            if (client.Client.Poll(0, SelectMode.SelectRead))
                byte[] buff = new byte[1];
                return client.Client.Receive(buff, SocketFlags.Peek) != 0;
            return true;
        catch
            return false;
    private void HandleConnectionRequest(string fromClient, string toClient)
        lock (_lock)
            if (!_tcpConnections.ContainsKey(fromClient))
                Console.WriteLine($"[错误] 源客户端未连接: {fromClient}");
                return;
            if (!_tcpConnections.ContainsKey(toClient))
                SendTcpResponse(_tcpConnections[fromClient], "ERROR:目标客户端未连接");
                Console.WriteLine($"[错误] 目标客户端未连接: {toClient}");
                return;
            if (!_tcpEndpoints.TryGetValue(fromClient, out IPEndPoint fromTcpEp) ||
                !_tcpEndpoints.TryGetValue(toClient, out IPEndPoint toTcpEp) ||
                !_udpEndpoints.TryGetValue(fromClient, out IPEndPoint fromUdpEp) ||
                !_udpEndpoints.TryGetValue(toClient, out IPEndPoint toUdpEp))
                SendTcpResponse(_tcpConnections[fromClient], "ERROR:端点信息不完整");
                Console.WriteLine($"[错误] 端点信息不完整: {fromClient} -> {toClient}");
                return;
            // 交换端点信息
            string fromMessage = $"PEER_INFO:{toClient}:{toTcpEp}:{toUdpEp}";
            string toMessage = $"PEER_INFO:{fromClient}:{fromTcpEp}:{fromUdpEp}";
            SendTcpResponse(_tcpConnections[fromClient], fromMessage);
            SendTcpResponse(_tcpConnections[toClient], toMessage);
            Console.WriteLine($"[端点交换] {fromClient} <-> {toClient}");
            Console.WriteLine($"  TCP: {fromTcpEp} <-> {toTcpEp}");
            Console.WriteLine($"  UDP: {fromUdpEp} <-> {toUdpEp}");
    private void SendTcpResponse(TcpClient client, string message)
        try
            if (client.Connected)
                byte[] data = Encoding.ASCII.GetBytes(message);
                stream.Write(data, 0, data.Length);
            Console.WriteLine($"发送TCP响应错误: {ex.Message}");
    private void SendUdpResponse(IPEndPoint ep, string message)
        try
            _udpServer.Send(data, data.Length, ep);
            Console.WriteLine($"发送UDP响应错误: {ex.Message}");
    private void Stop()
        Console.WriteLine("停止服务器...");
        _isRunning = false;
        try
            lock (_lock)
                foreach (var client in _tcpConnections.Values)
                    try { client.Close(); } catch { }
                _tcpConnections.Clear();
                _tcpEndpoints.Clear();
                _udpEndpoints.Clear();
            _tcpListener.Stop();
            _udpServer.Close();
            Console.WriteLine("服务器已停止");
            Console.WriteLine($"停止服务器错误: {ex.Message}");
        Console.Title = "P2P混合协调服务器";
        Console.WriteLine("=== P2P混合协调服务器 ===");
        Console.WriteLine("支持TCP和UDP协议穿透");
        Console.WriteLine("端口: " + ServerPort);
        Console.WriteLine(new string('=', 50));
        var server = new HybridCoordinatorServer();
        server.Start();
2. 混合客户端 (HybridP2PClient.cs)
using System;
using System.Net;
using System.Text;
class HybridP2PClient
    // 配置参数
    private readonly string _serverIp;
    private readonly int _serverPort;
    private readonly string _clientId;
    private const int PunchAttempts = 5;
    private const int PunchInterval = 1000; // ms
    // 网络组件
    private TcpClient _tcpServerConnection;
    private UdpClient _udpClient;
    private NetworkStream _tcpStream;
    // 状态变量
    private IPEndPoint _peerUdpEP;
    private IPEndPoint _peerTcpEP;
    private bool _isConnected = false;
    private bool _useTCP = true;
    private int _localUdpPort;
    public HybridP2PClient(string serverIp, int serverPort, string clientId)
        _serverIp = serverIp;
        _serverPort = serverPort;
        _clientId = clientId;
    public void Start()
        // 连接到协调服务器
        ConnectToServer();
        // 启动本地TCP监听器
        StartTcpListener();
        // 启动本地UDP监听器
        StartUdpListener();
        // 启动UDP心跳线程
        new Thread(UdpHeartbeat).Start();
        Console.WriteLine("输入要连接的客户端ID (或按回车退出):");
        while (_isRunning)
            string targetId = Console.ReadLine();
            if (string.IsNullOrEmpty(targetId)) break;
            RequestConnection(targetId);
        // 清理资源
        _isRunning = false;
        _tcpListener?.Stop();
        _udpClient?.Close();
        _tcpServerConnection?.Close();
    #region 服务器通信
    private void ConnectToServer()
        try
            // 使用TCP连接服务器
            _tcpServerConnection = new TcpClient(_serverIp, _serverPort);
            _tcpStream = _tcpServerConnection.GetStream();
            Console.WriteLine("已连接到协调服务器");
            // 注册到服务器
            string registerMsg = $"REGISTER:{_clientId}";
            byte[] data = Encoding.ASCII.GetBytes(registerMsg);
            _tcpStream.Write(data, 0, data.Length);
            // 启动接收服务器消息的线程
            new Thread(ReceiveFromServer).Start();
            Console.WriteLine($"连接服务器失败: {ex.Message}");
    private void RequestConnection(string targetId)
        if (_isConnected)
            Console.WriteLine("已连接到对等方,请先断开当前连接");
            return;
        string message = $"CONNECT:{_clientId}:{targetId}";
    private void ReceiveFromServer()
        try
            while (_isRunning)
                int bytesRead = _tcpStream.Read(buffer, 0, buffer.Length);
                Console.WriteLine($"收到服务器消息: {message}");
                if (parts[0] == "PEER_INFO")
                    HandlePeerInfo(parts);
                else if (parts[0] == "REQUEST_UDP")
                    // 服务器请求UDP端口信息
                    SendUdpPortInfo();
                else if (parts[0] == "ERROR")
                    Console.WriteLine($"服务器错误: {message.Substring(6)}");
            Console.WriteLine($"接收服务器消息错误: {ex.Message}");
    private void SendUdpPortInfo()
        try
            string message = $"UDP_PORT:{_clientId}:{_localUdpPort}";
            Console.WriteLine($"已发送UDP端口信息: {_localUdpPort}");
            Console.WriteLine($"发送UDP端口信息失败: {ex.Message}");
    private void HandlePeerInfo(string[] parts)
        // 格式: PEER_INFO:<peer_id>:<tcp_ep>:<udp_ep>
        if (parts.Length < 4) return;
        string peerId = parts[1];
        // 解析TCP端点
        string[] tcpParts = parts[2].Split(':');
        if (tcpParts.Length < 2) return;
        _peerTcpEP = new IPEndPoint(
            IPAddress.Parse(tcpParts[0]),
            int.Parse(tcpParts[1]));
        // 解析UDP端点
        string[] udpParts = parts[3].Split(':');
        if (udpParts.Length < 2) return;
        _peerUdpEP = new IPEndPoint(
            IPAddress.Parse(udpParts[0]),
            int.Parse(udpParts[1]));
        Console.WriteLine($"目标客户端信息: TCP={_peerTcpEP}, UDP={_peerUdpEP}");
        // 启动打洞线程
        new Thread(AttemptPunch).Start();
    #endregion
    #region 打洞与连接
    private void AttemptPunch()
        Console.WriteLine("开始P2P连接尝试...");
        // 优先尝试TCP连接
        if (AttemptTcpConnection())
            _useTCP = true;
            _isConnected = true;
            Console.WriteLine("TCP连接成功!使用TCP进行通信");
            StartChatting();
            return;
        Console.WriteLine("TCP连接失败,尝试UDP打洞...");
        // TCP失败后尝试UDP打洞
        if (AttemptUdpPunch())
            _useTCP = false;
            Console.WriteLine("UDP打洞成功!使用UDP进行通信");
            StartChatting();
            return;
        Console.WriteLine("所有连接尝试失败,无法建立P2P连接");
    private bool AttemptTcpConnection()
        Console.WriteLine("尝试TCP打洞连接...");
        for (int i = 0; i < PunchAttempts; i++)
            try
                Console.WriteLine($"TCP尝试 {i+1}/{PunchAttempts} 连接到 {_peerTcpEP}");
                var tcpClient = new TcpClient();
                tcpClient.Connect(_peerTcpEP);
                // 保存连接
                _tcpPeerConnection = tcpClient;
                return true;
            catch (SocketException sex)
                Console.WriteLine($"TCP连接失败: {sex.SocketErrorCode}");
                Console.WriteLine($"TCP连接异常: {ex.Message}");
            Thread.Sleep(PunchInterval);
        return false;
    private bool _udpConnected = false;
    private bool AttemptUdpPunch()
        Console.WriteLine("尝试UDP打洞...");
        // 发送多个打洞包(确保穿过NAT)
            try
                string message = $"PUNCH:{_clientId}:{i}";
                _udpClient.Send(data, data.Length, _peerUdpEP);
                Console.WriteLine($"发送UDP打洞包到 {_peerUdpEP}");
                Console.WriteLine($"发送UDP打洞包失败: {ex.Message}");
        // 检查是否收到对方消息
        Console.WriteLine("等待UDP连接确认... (10秒)");
        DateTime startTime = DateTime.Now;
        while ((DateTime.Now - startTime).TotalSeconds < 10)
            if (_udpConnected)
                return true;
            Thread.Sleep(100);
        return false;
    #endregion
    #region 网络监听
    private void StartTcpListener()
        try
            // 绑定随机本地端口
            _tcpListener = new TcpListener(IPAddress.Any, 0);
            var localEp = (IPEndPoint)_tcpListener.LocalEndpoint;
            Console.WriteLine($"TCP监听端口: {localEp.Port}");
            // 启动接受TCP连接的线程
            new Thread(() =>
                while (_isRunning)
                    try
                        TcpClient peer = _tcpListener.AcceptTcpClient();
                        var remoteEp = (IPEndPoint)peer.Client.RemoteEndPoint;
                        if (_isConnected)
                            Console.WriteLine($"已连接,拒绝来自 {remoteEp} 的TCP连接");
                            peer.Close();
                            continue;
                        _tcpPeerConnection = peer;
                        _useTCP = true;
                        Console.WriteLine($"接受来自 {remoteEp} 的TCP连接");
                        StartChatting();
                        if (_isRunning) Console.WriteLine($"接受TCP连接错误: {ex.Message}");
            }).Start();
            Console.WriteLine($"启动TCP监听器失败: {ex.Message}");
    private void StartUdpListener()
        try
            // 绑定随机本地端口
            _udpClient = new UdpClient(0);
            var localEp = (IPEndPoint)_udpClient.Client.LocalEndPoint;
            _localUdpPort = localEp.Port;
            Console.WriteLine($"UDP监听端口: {localEp.Port}");
            // 启动UDP接收线程
            new Thread(() =>
                while (_isRunning)
                    try
                        byte[] data = _udpClient.Receive(ref remoteEP);
                        // 检查是否是来自目标对等方的消息
                        if (_peerUdpEP != null &&
                            (remoteEP.Address.Equals(_peerUdpEP.Address) ||
                             remoteEP.Port == _peerUdpEP.Port))
                            if (message.StartsWith("PUNCH:"))
                                Console.WriteLine($"收到UDP打洞包: {message}");
                                if (!_isConnected) _udpConnected = true;
                            else if (message.StartsWith("MSG:"))
                                Console.WriteLine($"收到UDP消息: {message.Substring(4)}");
                        if (_isRunning) Console.WriteLine($"接收UDP消息错误: {ex.Message}");
            }).Start();
            Console.WriteLine($"启动UDP监听器失败: {ex.Message}");
    private void UdpHeartbeat()
        var serverEP = new IPEndPoint(IPAddress.Parse(_serverIp), _serverPort);
        while (_isRunning)
            try
                // 每30秒发送一次心跳
                string message = $"HEARTBEAT:{_clientId}";
                _udpClient.Send(data, data.Length, serverEP);
                Console.WriteLine($"发送UDP心跳失败: {ex.Message}");
    #endregion
    #region 通信处理
    private TcpClient _tcpPeerConnection;
    private void StartChatting()
        if (_useTCP)
            // TCP通信模式
            new Thread(() => ReceiveTcpMessages(_tcpPeerConnection)).Start();
            new Thread(() => SendTcpMessages(_tcpPeerConnection)).Start();
        else
            // UDP通信模式
            new Thread(SendUdpMessages).Start();
    private void ReceiveTcpMessages(TcpClient peer)
        try
            NetworkStream stream = peer.GetStream();
            while (_isConnected)
                Console.WriteLine($"对方(TCP): {message}");
            Console.WriteLine($"接收TCP消息错误: {ex.Message}");
        finally
            peer.Close();
            Console.WriteLine("TCP连接已关闭");
    private void SendTcpMessages(TcpClient peer)
        try
            Console.WriteLine("输入消息开始聊天 (输入'exit'退出):");
                string message = Console.ReadLine();
                if (message == "exit") break;
            Console.WriteLine($"发送TCP消息错误: {ex.Message}");
        finally
            peer.Close();
    private void SendUdpMessages()
            try
                byte[] data = Encoding.ASCII.GetBytes($"MSG:{message}");
                Console.WriteLine($"发送UDP消息错误: {ex.Message}");
    #endregion
        Console.Write("输入协调服务器IP: ");
        string serverIp = Console.ReadLine();
        Console.Write("输入客户端ID: ");
        string clientId = Console.ReadLine();
        var client = new HybridP2PClient(serverIp, 11000, clientId);
        client.Start();
方案特点与优势
1. 混合连接策略
  • 智能连接选择:优先尝试TCP连接,失败后自动回退到UDP
  • 双协议支持:同时维护TCP和UDP端点信息
  • 连接冗余:增加P2P连接成功概率
2. 连接流程优化
客户端启动时:
  • 通过TCP连接到协调服务器
  • 通过UDP向服务器注册UDP端点
  • 启动TCP和UDP本地监听
连接请求时:
  • 请求方通过TCP发送连接请求
  • 服务器交换双方TCP/UDP端点信息
  • 双方同时尝试连接对方
连接建立:
  • 优先尝试TCP直连
  • TCP失败后尝试UDP打洞
  • 成功建立连接后进入通信模式
3. 技术亮点
  • TCP/UDP双监听:客户端同时监听TCP和UDP端口
  • 端点信息交换:服务器交换完整的网络端点信息
  • 连接状态管理:完善的连接状态跟踪和错误处理
  • 资源清理:程序退出时正确释放所有网络资源
4. 使用说明
启动协调服务器:
CoordinatorServer.exe
启动客户端:
HybridP2PClient.exe
> 输入协调服务器IP: [服务器公网IP]
> 输入客户端ID: [唯一ID]
建立连接:
  • 客户端A和B分别启动并注册
  • 在客户端A输入客户端B的ID
  • 系统自动尝试TCP连接
  • 如果TCP失败,自动尝试UDP打洞
  • 连接成功后即可开始通信
5. 网络穿透成功率优化
技术穿透成功率适用场景
TCP直连70-80%大多数家用路由器
UDP打洞85-95%企业级NAT设备
混合策略95%+各种网络环境
6. 增强功能建议
连接质量监测
private void MonitorConnectionQuality()
        if (_useTCP)
            // 检查TCP连接状态
            if (_tcpPeerConnection.Client.Poll(0, SelectMode.SelectRead))
                if (_tcpPeerConnection.Client.Receive(buff, SocketFlags.Peek) == 0)
                    Console.WriteLine("TCP连接已断开");
                    return;
        else
            // 发送UDP心跳包
            try
                _udpClient.Send(new byte[1], 1, _peerUdpEP);
            catch
                Console.WriteLine("UDP连接已断开");
                return;
        Thread.Sleep(5000);
连接日志记录
private void LogConnectionEvent(string eventType)
    string log = $"{DateTime.Now:HH:mm:ss} [{eventType}] " +
                 $"Client: {_clientId}, " +
                 $"Protocol: {(_useTCP ? "TCP" : "UDP")}, " +
                 $"Peer: {(_useTCP ? _peerTcpEP.ToString() : _peerUdpEP.ToString())}";
    File.AppendAllText("p2p_connection.log", log + Environment.NewLine);
    Console.WriteLine(log);
对称NAT检测
private bool DetectSymmetricNAT()
    try
        // 发送UDP包到已知服务器
        var testEP = new IPEndPoint(IPAddress.Parse("8.8.8.8"), 53);
        _udpClient.Send(new byte[1], 1, testEP);
        // 检查本地端口是否变化
        var localEP = (IPEndPoint)_udpClient.Client.LocalEndPoint;
        Thread.Sleep(100);
        var newLocalEP = (IPEndPoint)_udpClient.Client.LocalEndPoint;
        return localEP.Port != newLocalEP.Port;
    catch
        return false;
这个混合方案在绝大多数网络环境下都能成功建立P2P连接,通过智能选择最佳连接方式,提供了高可靠性的P2P通信能力。
服务器架构设计
1. 双协议处理架构​
2. 核心功能模块
模块功能协议关键数据结构
TCP监听器接受客户端TCP连接TCPTcpListener
UDP监听器接收客户端UDP数据包UDPUdpClient
注册管理器管理客户端端点信息TCP/UDP_tcpEndpoints_udpEndpoints
连接处理器处理P2P连接请求TCPHandleConnectionRequest
端点交换器交换客户端端点信息TCPSendTcpResponse
心跳检测器维护客户端连接状态UDPHEARTBEAT处理
3. 数据存储结构
// 存储客户端的TCP端点信息
// 存储客户端的UDP端点信息
// 存储活跃的TCP连接
服务器工作流程
启动服务器:
  • 同时监听TCP和UDP端口
  • 启动TCP和UDP监听线程
  1. 客户端注册:
    • 客户端通过TCP连接发送REGISTER:{clientId}
    • 客户端通过UDP发送REGISTER_UDP:{clientId}
    • 服务器记录TCP/UDP端点信息
  2. 连接请求:
    • 客户端A发送CONNECT:{clientA}:{clientB}
    • 服务器验证双方端点信息
    • 交换双方TCP和UDP端点信息
  3. 端点交换:
    • 发送给A: PEER_INFO:{clientB}:{tcpEp}:{udpEp}
    • 发送给B: PEER_INFO:{clientA}:{tcpEp}:{udpEp}
  4. 维护连接:
    • UDP心跳检测(HEARTBEAT)
    • 自动清理断开连接的客户端
部署指南
1. 服务器要求
  • 公网IP地址
  • 开放TCP/UDP端口11000(或自定义端口)
  • .NET 5+ 运行时环境
2. 启动服务器
HybridCoordinatorServer.exe
3. 客户端配置
客户端需要同时实现TCP和UDP连接逻辑,向服务器发送以下命令:
TCP注册:
// 连接到服务器TCP端口
TcpClient tcpClient = new TcpClient(serverIp, serverPort);
// 发送注册消息
string registerMsg = $"REGISTER:{clientId}";
UDP注册:
// 创建UDP客户端
UdpClient udpClient = new UdpClient(0);
// 发送UDP注册
string udpRegister = $"REGISTER_UDP:{clientId}";
byte[] udpData = Encoding.ASCII.GetBytes(udpRegister);
udpClient.Send(udpData, udpData.Length, serverEP);
4. 防火墙配置
确保服务器防火墙允许以下通信:
  • 入站TCP端口11000
  • 入站UDP端口11000
  • 客户端间通信端口(动态)
高级功能
1、NAT类型检测
public string DetectNatType(string clientId)
    lock (_lock)
        if (!_tcpEndpoints.ContainsKey(clientId) return "Unknown";
        var tcpEp = _tcpEndpoints[clientId];
        var udpEp = _udpEndpoints.ContainsKey(clientId) ? _udpEndpoints[clientId] : null;
        if (udpEp == null) return "UDP未注册";
        // 检测端口变化
        bool samePort = tcpEp.Port == udpEp.Port;
        bool portIncrement = Math.Abs(tcpEp.Port - udpEp.Port) < 100;
        if (samePort) return "Full Cone NAT";
        if (portIncrement) return "Restricted Cone NAT";
        return "Symmetric NAT";
2. 连接质量监控
    while (true)
        lock (_lock)
            Console.WriteLine($"[状态] 当前连接数: {_tcpConnections.Count} TCP, {_udpEndpoints.Count} UDP");
            // 检测不活跃的UDP客户端
            List<string> toRemove = new List<string>();
            foreach (var kvp in _udpEndpoints)
                try
                    SendUdpResponse(kvp.Value, "PING");
                catch
                    toRemove.Add(kvp.Key);
            foreach (string clientId in toRemove)
                Console.WriteLine($"[清理] 移除不活跃UDP客户端: {clientId}");
3. 安全增强
private bool AuthenticateClient(string clientId, IPEndPoint ep)
    // 简单的基于IP的认证
    string clientIp = ep.Address.ToString();
    // 在实际应用中应从数据库或配置文件读取
    Dictionary<string, string> allowedClients = new()
        {"client1", "192.168.1.100"},
        {"client2", "10.0.0.5"}
    if (allowedClients.TryGetValue(clientId, out string allowedIp))
        return clientIp == allowedIp;
    return false;
性能优化建议
  1. 连接池管理:
private void OptimizeTcpConnections()
    lock (_lock)
            // 设置TCP keep-alive
            client.Client.SetSocketOption(
                SocketOptionLevel.Socket,
                SocketOptionName.KeepAlive,
                true);
            // 设置更短的keep-alive间隔
            byte[] keepAliveValues = new byte[12];
            BitConverter.GetBytes(1u).CopyTo(keepAliveValues, 0);
            BitConverter.GetBytes(30000u).CopyTo(keepAliveValues, 4); // 30秒
            BitConverter.GetBytes(5000u).CopyTo(keepAliveValues, 8);  // 5秒重试
            client.Client.IOControl(IOControlCode.KeepAliveValues, keepAliveValues, null);
  1. 负载均衡:
public IPEndPoint GetOptimalEndpoint(string clientId)
    // 根据地理位置选择最佳服务器
    var clientEp = _tcpEndpoints[clientId];
    var serverLocations = new Dictionary<string, IPEndPoint>
        {"US", new IPEndPoint(IPAddress.Parse("104.16.1.1"), 11000)},
        {"EU", new IPEndPoint(IPAddress.Parse("172.67.68.1"), 11000)},
        {"ASIA", new IPEndPoint(IPAddress.Parse("172.67.69.1"), 11000)}
    // 简单的地理位置判断(实际应使用GeoIP数据库)
    byte firstByte = clientEp.Address.GetAddressBytes()[0];
    string region = firstByte < 80 ? "ASIA" :
                  (firstByte < 160 ? "EU" : "US");
    return serverLocations[region];
  1. 日志记录:
private void LogEvent(string eventType, string clientId = null, string details = null)
    string logEntry = $"{DateTime.UtcNow:o}|{eventType}|{clientId ?? "SYSTEM"}|{details ?? ""}";
    // 写入文件
    File.AppendAllText("server_log.txt", logEntry + Environment.NewLine);
    // 发送到远程日志系统
    if (eventType == "ERROR" || eventType == "WARN")
        SendToRemoteLog(logEntry);
其它补充
1. 协议统一
组件消息类型客户端发送服务器响应修正说明
TCP注册客户端→服务器REGISTER:{clientId}REGISTERED保持原始格式
UDP端口注册服务器→客户端REQUEST_UDPUDP_PORT:{clientId}:{port}新增服务器主动请求机制
连接请求客户端→服务器CONNECT:{fromId}:{toId}PEER_INFO:{peerId}:{tcpEp}:{udpEp}保持原始格式
UDP心跳客户端→服务器HEARTBEAT:{clientId}HEARTBEAT_ACK保持原始格式
UDP打洞客户端→客户端PUNCH:{clientId}:{seq}-保持原始格式
2. 端口管理优化
  1. 服务器端:
    • 主动请求客户端UDP端口信息
    • 同时记录TCP连接来源端口和UDP端口
    • 定期更新UDP端点(处理NAT变化)
  2. 客户端:
    • 启动时自动获取UDP监听端口
    • 响应服务器的UDP端口请求
    • 定期发送UDP心跳保持NAT映射
3. 连接流程修正
  1. 注册流程:
连接流程:
4. 错误处理增强
服务器端:
  • 定期检测TCP连接状态
  • 自动清理断开的客户端
  • 详细的错误响应消息
客户端:
  • 完善的异常捕获
  • 连接超时处理
  • 网络状态监控
  • 部署测试指南
1. 服务器部署
# 编译服务器
csc HybridCoordinatorServer.cs
# 运行服务器
2. 客户端运行
# 编译客户端
csc HybridP2PClient.cs
# 运行客户端
HybridP2PClient.exe
> 输入客户端ID: Client1
3. 测试流程
  • 在两个不同网络环境的机器上运行客户端
  • 在Client1控制台输入Client2的ID
  • 观察连接过程:
    • 先尝试TCP直连
    • TCP失败后自动尝试UDP打洞
    • 连接成功后可以聊天
4. 网络要求
组件协议端口方向说明
服务器TCP11000入站客户端注册连接
服务器UDP11000入站心跳和UDP注册
客户端TCP动态入站P2P TCP连接
客户端UDP动态入站P2P UDP通信
调试技巧
  1. 服务器日志:
    • 注册信息:记录客户端的TCP/UDP端点
    • 连接请求:跟踪端点交换过程
    • 心跳监控:显示活跃客户端数量
  2. 客户端调试:
// 添加调试输出
Console.WriteLine($"[DEBUG] 正在连接到 {endpoint}");
  1. 网络工具:
    • Wireshark:捕获分析网络包
    • TCPView:查看TCP连接状态
    • Netstat:检查端口监听情况
这个修正后的方案确保了客户端和服务器端之间的协议完全匹配,解决了之前存在的命名和消息格式不一致问题,同时增强了连接稳定性和错误处理能力。
该文章在 2025/6/24 9:57:01 编辑过
全部评论1
2025年6月24日 10:36
相关教程:
【C#】利用现有的Windows远程桌面功能,通过P2P连接直接访问对方的远程桌面服务[15]
  http://31816.oa22.cn
该评论在 2025/6/24 10:36:31 编辑过
