Asp.net执行服务器端的可执行文件
2011年4月22日 14:49 本文热度 9522
方法一、process
string user = "sde";
string user1= "sys";
string pwd1 = "sys";
string pwd = "sde";
string db = "wbz";
string dir = @"c:\wbz1";
string cmd =@"/c exp "+user+"/"+pwd+"@"+db+" owner="+user+" file="+dir+".dmp";
Process myprocess=Process.Start("cmd", cmd);
myprocess.WaitForExit();
myprocess.Exited +=new EventHandler(myprocess_Exited);
In order to execute exp.exe of Oracle,   IIS must has powerful previlege. In Web.Config, identity node must be added.
<identity impersonate="true" userName="Administrator" password="passwd" />
In machine.config, the processModel node’s userName attribute should be changed to SYSTEM.
<processModel userName="SYSTEM" password="AutoGenerate" />
方法二、ASPEXEC组件法
ASPEXEC ASPEXEC是一个免费的ASP组件,它可以执行Server端DOS与Windows的应用程序。
ASPEXEC 3.0语法使用说明:
1.使用ASPEXEC之前,请先注册ASPEXEC.DLL这一个组件,其注册语法如下:
   Regsvr32 ASPEXEC.DLL
2.语法说明
   Set Executor = Server.CreateObject("ASPExec.Execute")
   '这是建立组件的语法
   Application
   '这是执行的应用程序的档名称与路径
   Executor.Application = "notepad.exe"
   Parameters
   '这是执行的应用程序的参数
   Executor.Parameters = "c:\autoexec.bat"
   TimeOut
   '这是执行应用程序的等待时间(ms)
   Executor.TimeOut = "6000"
   ShowWindow
   '这是执行的应用程式时是否要显示视窗
   Executor.ShowWindow = Ture
   ExecuteDosApp
   'Executes the specified app as a DOS app and returns stdio as string
   Executor.ExecuteDosApp
   ExecuteWinAppAndWait
   'Execute the specified app as a Windows app and wait for the specified timeout if exec is successful
   ExecuteWinApp
   'Execute the specified app as a Windows app and return result code immediately
3.范例
   Executor.ShowWindow = True
   Response.Write "Attempting to execute " & Executor.Application & "<br>"
   strResult = Executor.ExecuteWinApp
   Response.Write "The result of this call was: " & strResult
该文章在 2011/4/22 14:49:12 编辑过
