搞懂C#文件压缩:SharpZipLib vs. DotNetZip,功能对比与实用代码一网打尽!
2023年12月3日 22:51 本文热度 5997
在C#中,有两个热门的文件压缩解析类库分别是SharpZipLib和DotNetZip。以下是它们的简要介绍以及使用实例代码。
1. SharpZipLib
功能:
  • 支持ZIP和GZip格式的压缩和解压缩。
  • 提供了对Tar和BZip2格式的支持。
  • 轻量级,易于使用。
优点:
  • 开源,广泛使用。
  • 灵活性较高,适用于多种压缩需求。
使用实例:
using System;
using ICSharpCode.SharpZipLib.Zip;
class Program
    static void Main()
        string sourceFolder = @"C:\Path\To\Your\Folder";
        string zipFile = @"C:\Path\To\Your\Archive.zip";
        ZipDirectory(sourceFolder, zipFile);
        Console.WriteLine("Compression completed.");
        string extractFolder = @"C:\Path\To\Your\Extracted";
        UnzipFile(zipFile, extractFolder);
        Console.WriteLine("Extraction completed.");
    static void ZipDirectory(string sourceFolder, string zipFile)
        using (ZipOutputStream zipStream = new ZipOutputStream(System.IO.File.create(zipFile)))
            zipStream.SetLevel(9); // 0 - store only to 9 - means best compression
            ZipFolder(sourceFolder, sourceFolder, zipStream);
            zipStream.Finish();
            zipStream.Close();
    static void ZipFolder(string rootFolder, string currentFolder, ZipOutputStream zipStream)
        string[] files = System.IO.Directory.GetFiles(currentFolder);
        foreach (string file in files)
            ZipFile(zipStream, currentFolder, file);
        string[] subFolders = System.IO.Directory.GetDirectories(currentFolder);
        foreach (string folder in subFolders)
            ZipFolder(rootFolder, folder, zipStream);
    static void ZipFile(ZipOutputStream zipStream, string rootFolder, string filePath)
        byte[] buffer = new byte[4096];
        string relativePath = filePath.Substring(rootFolder.Length + 1);
        ZipEntry entry = new ZipEntry(relativePath);
        zipStream.PutNextEntry(entry);
        using (System.IO.FileStream fs = System.IO.File.OpenRead(filePath))
            int sourceBytes;
            do
                sourceBytes = fs.Read(buffer, 0, buffer.Length);
                zipStream.Write(buffer, 0, sourceBytes);
            } while (sourceBytes > 0);
    static void UnzipFile(string zipFile, string extractFolder)
        using (ZipInputStream zipStream = new ZipInputStream(System.IO.File.OpenRead(zipFile)))
            ZipEntry entry;
            while ((entry = zipStream.GetNextEntry()) != null)
                string entryName = entry.Name;
                string fullZipToPath = System.IO.Path.Combine(extractFolder, entryName);
                string directoryName = System.IO.Path.GetDirectoryName(fullZipToPath);
                if (directoryName.Length > 0)
                    System.IO.Directory.createDirectory(directoryName);
                if (entry.IsFile)
                    using (System.IO.FileStream streamWriter = System.IO.File.create(fullZipToPath))
                        int sourceBytes;
                        do
                            sourceBytes = zipStream.Read(buffer, 0, buffer.Length);
                            streamWriter.Write(buffer, 0, sourceBytes);
2. DotNetZip
功能:
  • 支持ZIP格式的压缩和解压缩。
  • 提供了对多卷和自解压缩ZIP文件的支持。
  • 具有更简单的API,易于使用。
优点:
  • 使用方便,简洁明了。
  • 集成度高,适合快速实现文件压缩解压缩功能。
使用实例:
using System;
using Ionic.Zip;
class Program
    static void Main()
        using (ZipFile zip = new ZipFile())
            zip.AddDirectory(sourceFolder);
            zip.Save(zipFile);
        using (ZipFile zip = ZipFile.Read(zipFile))
            zip.ExtractAll(extractFolder, ExtractExistingFileAction.OverwriteSilently);
以上两个例子都提供了基本的目录压缩和解压缩功能,你可以根据具体需求进行进一步定制。确保在实际项目中进行充分的测试和适当的错误处理。
该文章在 2023/12/3 22:51:17 编辑过
