XMLDOM手册
2011年4月13日 14:51
本文热度 9419
XMLDOM是用来访问和操作XML文档的编程接口规范。
1、简介
XMLDOM被设计为可用于任何语言和任何操作系统。借助DOM,程序员可以创建XML文档、遍历其结构,增、改、删其元素。DOM将整个XML文档视作一棵树,文档级的元素是树的根。
2、MS的XML解析,IE5.0以上。
是一个COM组件,至少包含下列对象:
(1)Micosoft.XMLDOM
(2)Micosoft.XMLDOM.parseError,有如下属性:
| Property |
Description |
| errorCode |
Returns a long integer error code |
| reason |
Returns a string explaining the reason for the error |
| line |
Returns a long integer representing the line number for the error |
| linePos |
Returns a long integer representing the line position for the error |
| srcText |
Returns a string containing the line that caused the error |
| url |
Returns the url pointing the loaded document |
| filePos |
Returns a long integer file position of the error |
(3)Microsoft.XMLHTTP,有如下属性:
| Property |
Description |
| readyState |
Returns the state of the document |
| responseBody |
Returns the response as an array of unsigned bytes |
| responseStream |
Returns the response as an IStream |
| responseText |
Returns the response as a string |
| responseXML |
Returns the response as an xml document |
| status |
Returns the status code as a number |
| statusText |
Returns the status as a string |
有如下方法:
| Property |
Description |
| abort() |
Cancel the current http request |
| getAllResponseHeaders() |
Returns the value of the http headers |
| getResponseHeader(headerName) |
Returns the value of one specified http header |
| open(method, url, async, userid, password) |
Opens http request, and specifies the information |
| send() |
Send the http request to the server |
| setRequestHeader(headerName,headerValue) |
Specifies the name of a http header |
(4)Node的类型
| nodeType |
Named Constant |
nodeTypeString |
nodeName |
nodeValue |
| 1 |
ELEMENT_NODE |
element |
tagName |
null |
| 2 |
ATTRIBUTE_NODE |
attribute |
name |
value |
| 3 |
TEXT_NODE |
text |
#text |
content of node |
| 4 |
CDATA_SECTION_NODE |
cdatasection |
#cdata-section |
content of node |
| 5 |
ENTITY_REFERENCE_NODE |
entityreference |
entity reference name |
null |
| 6 |
ENTITY_NODE |
entity |
entity name |
null |
| 7 |
PROCESSING_INSTRUCTION_NODE |
processinginstruction |
target |
content of node |
| 8 |
COMMENT_NODE |
comment |
#comment |
comment text |
| 9 |
DOCUMENT_NODE |
document |
#document |
null |
| 10 |
DOCUMENT_TYPE_NODE |
documenttype |
doctype name |
null |
| 11 |
DOCUMENT_FRAGMENT_NODE |
documentfragment |
#document fragment |
null |
| 12 |
NOTATION_NODE |
notation |
notation name |
null |
W3C规定的属性:
| Property |
Description |
| attributes |
Returns a NamedNodeMap containing all attributes for this node |
| childNodes |
Returns a NodeList containing all the child nodes for this node |
| firstChild |
Returns the first child node for this node |
| lastChild |
Returns the last child node for this node |
| nextSibling |
Returns the next sibling node. Two nodes are siblings if they have the same parent node |
| nodeName |
Returns the nodeName, depending on the type |
| nodeType |
Returns the nodeType as a number |
| nodeValue |
Returns, or sets, the value of this node, depending on the type |
| ownerDocument |
Returns the root node of the document |
| parentNode |
Returns the parent node for this node |
| previousSibling |
Returns the previous sibling node. Two nodes are siblings if they have the same parent node |
W3C规定的方法:
| Method |
Description |
| appendChild(newChild) |
Appends the node newChild at the end of the child nodes for this node |
| cloneNode(boolean) |
Returns an exact clone of this node. If the boolean value is set to true, the cloned node contains all the child nodes as well |
| hasChildNodes() |
Returns true if this node has any child nodes |
| insertBefore(newNode,refNode) |
Inserts a new node, newNode, before the existing node, refNode |
| removeChild(nodeName) |
Removes the specified node, nodeName |
| replaceChild(newNode,oldNode) |
Replaces the oldNode, with the newNode |
(5)NodeList的W3C规定的属性和方法。
| Property |
Description |
| length |
Returns the number of nodes in a nodeList |
| Method |
Description |
| item |
Returns a specific node in the nodeList |
XMLHTTP对象及其方法
MSXML中提供了Microsoft.XMLHTTP对象,能够完成从数据包到Request对象的转换以及发送任务。
创建XMLHTTP对象的语句如下:
Set objXML = CreateObject("Msxml2.XMLHTTP") 或
Set objXML = CreateObject(“Microsoft.XMLHTTP”)
' Or, for version 3.0 of XMLHTTP, use:
' Set xml = Server.CreateObject("MSXML2.ServerXMLHTTP")
对象创建后调用Open方法对Request对象进行初始化,语法格式为:
poster.open http-method, url, async, userID, password
Open方法中包含了5个参数,前三个是必要的,后两个是可选的(在服务器需要进行身份验证时提供)。参数的含义如下所示:
http-method: HTTP的通信方式,比如GET或是 POST
url: 接收XML数据的服务器的URL地址。通常在URL中要指明 ASP或CGI程序
async: 一个布尔标识,说明请求是否为异步的。如果是异步通信方式(true),客户机就不等待服务器的响应;如果是同步方式(false),客户机就要等到服务器返回消息后才去执行其他操作
userID 用户ID,用于服务器身份验证
password 用户密码,用于服务器身份验证
XMLHTTP对象的Send方法
用Open方法对Request对象进行初始化后,调用Send方法发送XML数据:
poster.send XML-data
Send方法的参数类型是Variant,可以是字符串、DOM树或任意数据流。发送数据的方式分为同步和异步两种。在异步方式下,数据包一旦发送完毕,就结束Send进程,客户机执行其他的操作;而在同步方式下,客户机要等到服务器返回确认消息后才结束Send进程。
XMLHTTP对象中的readyState属性能够反映出服务器在处理请求时的进展状况。客户机的程序可以根据这个状态信息设置相应的事件处理方法。属性值及其含义如下表所示:
值 说明
0 Response对象已经创建,但XML文档上载过程尚未结束
1 XML文档已经装载完毕
2 XML文档已经装载完毕,正在处理中
3 部分XML文档已经解析
4 文档已经解析完毕,客户端可以接受返回消息
客户机处理响应信息
客户机接收到返回消息后,进行简单的处理,基本上就完成了C/S之间的一个交互周期。客户机接收响应是通过XMLHTTP对象的属性实现的:
● responseTxt:将返回消息作为文本字符串;
● responseXML:将返回消息视为XML文档,在服务器响应消息中含有XML数据时使用;
● responseStream:将返回消息视为Stream对象。
下面的xml文件是动态生成的最后用xmlHTTP传送出去,这是一个在客户端JavaScript脚本里的内容,当然你也可以写在服务器,但是要相应的改一些东西:(仅供大家参考,了解它的用法)
var xmlDoc=new ActiveXObject("MSXML2.DOMDocument");
flag=xmlDoc.loadXML("");
newNode =xmlDoc.createElement("编码")
MarkNode=xmlDoc.documentElement.appendChild(newNode);
newNode =xmlDoc.createElement("StartMark")
newNode.text=StartMark;
MarkNode.appendChild(newNode)
newNode =xmlDoc.createElement("EndMark")
newNode.text=EndMark;
newNode =xmlDoc.createElement("日期")
DateNode=xmlDoc.documentElement.appendChild(newNode);
newNode =xmlDoc.createElement("StartDate");
newNode.text=StartDate;
DateNode.appendChild(newNode)
newNode =xmlDoc.createElement("EndDate")
newNode.text=EndDate;
DateNode.appendChild(newNode);
newNode =xmlDoc.createElement("数量")
SLNode =xmlDoc.documentElement.appendChild(newNode);
newNode =xmlDoc.createElement("StartSL")
newNode.text=StartShuL
SLNode.appendChild(newNode)
newNode =xmlDoc.createElement("EndSL");
newNode.text=EndShuL
SLNode.appendChild(newNode);
newNode =xmlDoc.createElement("单价")
DJNode =xmlDoc.documentElement.appendChild(newNode)
newNode =xmlDoc.createElement("StartDJ")
newNode.text=StartDanJ;
DJNode.appendChild(newNode);
newNode =xmlDoc.createElement("EndDJ")
newNode.text=EndDanJ;
newNode =xmlDoc.createElement("金额")
JENode =xmlDoc.documentElement.appendChild(newNode)
newNode =xmlDoc.createElement("StartJE")
newNode.text=StartJinE
JENode.appendChild(newNode)
newNode =xmlDoc.createElement("EndJE")
newNode.text=EndJinE
newNode =xmlDoc.createElement("仓库代码")
newNode.text=CK;
newNode =xmlDoc.createElement("票号")
newNode.text=RKPH;
newNode =xmlDoc.createElement("单位代码")
newNode.text=CorpName;
newNode =xmlDoc.createElement("BiaoShi")
newNode.text=Biaoshi
newNode =xmlDoc.createElement("FindCate")
newNode.text=FindCate
var xh =new ActiveXObject("MSXML2.XMLHTTP")
xh.open("POST","Find.asp",false)
xh.setRequestHeader("Content-Type","text/xml")
xh.setRequestHeader("Content-Type","gb2312")
xh.send(xmlDoc);
我的每一个newNode的text值是一个变量,也就是我客户端form 中input的值
该文章在 2011/4/13 14:52:24 编辑过
