[点晴永久免费OA]C#动态添加IIS个各个版本的MIME类型
2022年4月19日 16:35 本文热度 7347
主要是介绍IIS6和IIS7。IIS6主要是运用System.DirectoryServices.dll,IIS7用到Microsoft.Web.Administration.dll,该DLL在IIS7目录中存在,拷贝即可。
代码如下:
/// <summary>
/// 取得IIS版本
/// </summary>
/// <returns></returns>
private int GetIISVersion()
DirectoryEntry getEntity = new DirectoryEntry("IIS://localhost/W3SVC/INFO");
string strVersion = getEntity.Properties["MajorIISVersionNumber"].Value.ToString();
return Convert.ToInt32(strVersion);
主体实现方法:
private void Main() {
//判断IIS版本
int iisVersion = this.GetIISVersion();
//IIS7
if (iisVersion > 6)
try
ServerManager server = new ServerManager();
Configuration confg = server.GetWebConfiguration(webSiteName); //webSiteName站点名称
ConfigurationSection section;
section = confg.GetSection("system.webServer/staticContent"); //取得MimeMap所有节点(路径为:%windir%\Windows\System32\inetsrv\config\applicationHost.config)
ConfigurationElement filesElement = section.GetCollection();
ConfigurationElementCollection filesCollection = filesElement.GetCollection();
ConfigurationElement newElement = filesCollection.createElement(); //新建MimeMap节点
newElement.Attributes["fileExtension"].Value = this.txtName.Text;
newElement.Attributes["mimeType"].Value = this.txtMimeType.Text;
if (filesCollection.Contains(newElement))
MessageBox.Show("您添加的类型已存在,请重新添加!");
return;
filesCollection.Add(newElement);
server.CommitChanges(); //更改目录
MessageBox.Show("添加成功!");
this.Close();
catch (Exception ex)
MessageBox.Show("eror:" + ex.Message.ToString());
else //IIS6
try
int id = this.GetselectIdByWebSiteName(webSiteName); //取得站点的标识符ID
DirectoryEntry path = new DirectoryEntry(string.Format("IIS://localhost/w3svc/{0}/root", id));
PropertyValueCollection propValues = path.Properties["MimeMap"];
string newExtension = this.txtName.Text; //扩展名
string newMimeType = this.txtMimeType.Text; //MIME类型
object exists = null;
foreach (object value in propValues)
IISOle.IISMimeType mimetypeObj = (IISOle.IISMimeType)value;
if (newExtension == mimetypeObj.Extension){exists = value;}
if (null != exists)
//propValues.Remove(exists);
return;
IISOle.MimeMapClass _NewMime = new IISOle.MimeMapClass(); //新建MIME类型
_NewMime.Extension = newExtension;
_NewMime.MimeType = newMimeType;
propValues.Add(_NewMime); //添加MIME类型
path.CommitChanges(); //更改目录
this.Close();
MessageBox.Show(ex.Message.ToString());
该文章在 2022/4/19 16:35:25 编辑过
