C#短网址算法
2021年1月29日 17:11 本文热度 7400
//62进制 public static int BASE_NUM = 62; //62进制字母顺序 public static final char[] array = {''G'', ''q'', ''w'', ''0'', ''H'', ''e'', ''T'', ''F'', ''9'', ''r'', ''V'', ''t'', ''y'', ''u'', ''N'', ''i'', ''6'', ''D'', ''o'', ''p'', ''L'', ''a'', ''s'', ''d'', ''K'', ''f'', ''g'', ''h'', ''j'', ''k'', ''4'', ''l'', ''z'', ''x'', ''c'', ''v'', ''b'', ''S'', ''n'', ''m'', ''1'', ''Z'', ''3'', ''5'', ''Q'', ''W'', ''E'', ''R'', ''7'', ''Y'', ''U'', ''I'', ''O'', ''2'', ''P'', ''A'', ''J'', ''X'', ''C'', ''B'', ''8'', ''M''}; /** * 将10进制数转为62进制字符串(短网址) * * @param number * @return */ public static String getShortUrlByLongNum(Long number) { Long rest = number; Stack<Character> stack = new Stack<Character>(); StringBuilder result = new StringBuilder(0); if (0 == rest) { return String.valueOf(array[0]); } while (rest != 0) { stack.add(array[new Long((rest - (rest / BASE_NUM) * BASE_NUM)).intValue()]); rest = rest / BASE_NUM; } for (; !stack.isEmpty(); ) { result.append(stack.pop()); } return result.toString(); } /** * 通过短网址返回10进制数 * * @param shortUrl * @return */ public static Long getLongNumByShortUrl(String shortUrl) { long multiple = 1; long result = 0; Character c; for (int i = 0; i < shortUrl.length(); i++) { c = shortUrl.charAt(shortUrl.length() - i - 1); result += valueOfCharacter(c) * multiple; multiple = multiple * BASE_NUM; } return result; } /** * 字母对应的值 如array数组 G对应0 q对应1 * * @param c * @return */ private static int valueOfCharacter(Character c) { for (int i = 0; i < array.length; i++) { if (c == array[i]) { return i; } } return -1; }
         准备一个被打乱的数组,存放A-Za-Z0-9这62个字符 ,预先产生一个网址ID,将这个ID通过 _10_to_62 解析转换成62进制的短网址符。
         存储ID,短网址code,页面URL  算法如下,很简单,时间效率也比较高,甚至,有了存储的ID,要不要存储短网址code都无所谓,
        这个算法时间复杂度本来就是n,而一般的短网址长度也就1~7位,时间复杂度也可以算作O(1)常量了。
该文章在 2021/1/29 17:11:11 编辑过
