Asp生成HTML方法大全
2010年11月26日 0:41 本文热度 10196
方法一:FSO
Set fs = CreateObject("Scripting.FileSystemObject")
NewFile=Server.MapPath("/asp/chap06/at/newfile.html")
'新建一文件/newfile.html,若该文件已存在,则覆盖它
Set a = fs.CreateTextFile(NewFile, True)
Response.Write"新文件已建立!"
a.close
File=Server.MapPath("newfile.html")
Set txt=fs.OpenTextFile(File,8,True) '打开成可以在结尾写入数据的文件
data1="这句话是使用WriteLine方法写入的哦!~~"
txt.WriteLine data1
data2="这句话是使用Write方法写入的哦!~~"
txt.Write data2
txt.Close
方法二:XMLHTTP
Set xml = Server.CreateObject("Microsoft.XMLHTTP")
'把下面的地址替换成你的首页的文件地址,一定要用http://开头的绝对路径,不能写相对路径
xml.Open "GET", "http://www.phpup.com", False
xml.Send
BodyText=xml.ResponseBody
BodyText=BytesToBstr(BodyText,"gb2312")
Set xml = Nothing
Dim fso, MyFile
Set fso = CreateObject("Scripting.FileSystemObject")
Set MyFile= fso.CreateTextFile(server.MapPath("aa.htm"), True)
MyFile.WriteLine(BodyText)
MyFile.Close
其他:
1
下面的例子是将、index.asp?id=1/index.asp?id=2/index.asp?id=3/这三个动态
页面,分别生成ndex1.htm,index2.htm,index3.htm存在根目录下面:
dim strUrl,Item_Classid,id,FileName,FilePath,Do_Url,Html_Temp
Html_Temp="<UL>"
For i=1 To 3
Html_Temp = Html_Temp&"<LI>"
Item_Classid = i
FileName = "Index"&Item_Classid&".htm"
FilePath = Server.MapPath("/")&"\"&FileName Html_Temp = Html_Temp&FilePath&"</LI>"
Do_Url = "http://"
Do_Url = Do_Url&Request.ServerVariables("SERVER_NAME")&"/main/index.asp"
Do_Url = Do_Url&"?Item_Classid="&Item_Classid
strUrl = Do_Url
dim objXmlHttp
set objXmlHttp = Server.createObject("Microsoft.XMLHTTP")
objXmlHttp.open "GET",strUrl,false
objXmlHttp.send()
Dim binFileData
binFileData = objXmlHttp.responseBody
Dim objAdoStream
set objAdoStream = Server.createObject("ADODB.Stream")
objAdoStream.Type = 1
objAdoStream.Open()
objAdoStream.Write(binFileData)
objAdoStream.SaveToFile FilePath,2
objAdoStream.Close()
Next
Html_Temp = Html_Temp&"<UL>"
Response.Write ( "成功生成文件:" )
Response.Write ( "<BR>" )
Response.Write Html_Temp
Function BytesToBstr(body,Cset)
dim objstream
set objstream = Server.CreateObject("adodb.stream")
objstream.Type = 1
objstream.Mode =3
objstream.Open
objstream.Write body
objstream.Position = 0
objstream.Type = 2
objstream.Charset = Cset
BytesToBstr = objstream.ReadText
objstream.Close
set objstream = nothing
End Function
2
<%@LANGUAGE="VBSCRIPT" CODEPAGE="936"%>
public tempelatefile,tmpdata
sub ofile()'打开文件,并把文件内容放到tmpdata
on error resume next
tmpdata=""
set Astream=Server.CreateObject ("Adodb.Stream")
Astream.type=2'文件类型文本
Astream.Mode = 3'读写
Astream.open
Astream.CharSet = "GB2312"'字符集
Astream.LoadFromFile(tempelatefile)'从文件装载
Assp=Astream.size
if err.number<>0 then
xz=-18
response.Write tempelatefile&"<br>"
err.clear
tmpdata=""
else
tmpdata=Astream.ReadText(Assp)
end if
end sub
sub save_file()
ofile()
recfilen=server.MapPath(dts)
Astream.Flush
Astream.close
Astream.type=2
Astream.Mode = 3
Astream.open
Astream.position=0
Astream.Writetext tmpdata,1'写入数据到stream
Astream.SaveToFile recfilen,2'保存到文件
end sub
function dts()'产生随机文件名
if len(month(now()))>1 then
mm=month(now())
else
mm="0"&month(now())
end if
if len(day(now()))>1 then
d=day(now())
else
d="0"&day(now())
end if
if len(hour(now()))>1 then
h=hour(now())
else
h="0"&hour(now())
end if
if len(minute(now()))>1 then
m=minute(now())
else
m="0"&minute(now())
end if
if len(second(now()))>1 then
s=second(now())
else
s="0"&second(now())
end if
Randomize
upperbound=9999
lowerbound=1000
rds=Int((upperbound - lowerbound + 1) * Rnd + lowerbound)
dts="htm/"&year(now())&mm&d&h&m&s&rds&".htm"
end function
title=request.Form("title")
content=request.Form("content")
tmpdata=replace(tmpdata,"<title></title>",title)'以拥护提交内容替换
tmpdata=replace(tmpdata,"<content></content>",content)
tempelatefile=server.MapPath("tempelate/1.htm")'模版文件
save_file()
该文章在 2010/11/26 0:41:18 编辑过
