title及alt提示个性化特效
2010年10月24日 18:45 本文热度 9422
[code] title及alt提示特效 <script language="javascript"> var pltsPop=null; var pltsoffsetX = 12; // 弹出窗口位于鼠标左侧或者右侧的距离;3-12 合适 var pltsoffsetY = 15; // 弹出窗口位于鼠标下方的距离;3-12 合适 var pltsTitle=""; document.write(''); function pltsinits() { document.onmouseover = plts; document.onmousemove = moveToMouseLoc; } function plts() { var o=event.srcElement; if(o.alt!=null && o.alt!=""){o.dypop=o.alt;o.alt=""}; if(o.title!=null && o.title!=""){o.dypop=o.title;o.title=""}; pltsPop=o.dypop; if(pltsPop!=null && pltsPop!="" && typeof(pltsPop)!="undefined") { pltsTipLayer.style.left=-1000; pltsTipLayer.style.display=''; var Msg=pltsPop.replace(/\n/g,"
"); Msg=Msg.replace(/\0x13/g,"
"); var re=/\{(.[^\{]*)\}/ig; if(!re.test(Msg))pltsTitle="『水木设计联盟』"; else{ re=/\{(.[^\{]*)\}(.*)/ig; pltsTitle=Msg.replace(re,"$1")+" "; re=/\{(.[^\{]*)\}/ig; Msg=Msg.replace(re,""); Msg=Msg.replace("
","");} var content = '
↖'+pltsTitle+'
'+Msg+'
'; pltsTipLayer.innerHTML=content; toolTipTalbe.style.width=Math.min(pltsTipLayer.clientWidth,document.body.clientWidth/2.2); moveToMouseLoc(); return true; } else { pltsTipLayer.innerHTML=''; pltsTipLayer.style.display='none'; return true; } } function moveToMouseLoc() { if(pltsTipLayer.innerHTML=='')return true; var MouseX=event.x; var MouseY=event.y; var popHeight=pltsTipLayer.clientHeight; var popWidth=pltsTipLayer.clientWidth; if(MouseY+pltsoffsetY+popHeight>document.body.clientHeight) { popTopAdjust=-popHeight-pltsoffsetY*1.5; pltsPoptop.style.display="none"; pltsPopbot.style.display=""; } else { popTopAdjust=0; pltsPoptop.style.display=""; pltsPopbot.style.display="none"; } if(MouseX+pltsoffsetX+popWidth>document.body.clientWidth) { popLeftAdjust=-popWidth-pltsoffsetX*2; topleft.style.display="none"; botleft.style.display="none"; topright.style.display=""; botright.style.display=""; } else { popLeftAdjust=0; topleft.style.display=""; botleft.style.display=""; topright.style.display="none"; botright.style.display="none"; } pltsTipLayer.style.left=MouseX+pltsoffsetX+document.body.scrollLeft+popLeftAdjust; pltsTipLayer.style.top=MouseY+pltsoffsetY+document.body.scrollTop+popTopAdjust; return true; } pltsinits(); </script> 链接提示效果:一个很酷的鼠标悬停特效,但有问题指教,我想知道怎么控制悬停时间 [/code]
该文章在 2010/10/24 18:45:38 编辑过
