c#使用HttpWebRequest上传文件同时携带其他参数
2017年3月22日 0:30 本文热度 12024
 这个小程序参考了另一位博友的代码,做了稍许调整,创建的两个Handler程序,一个上传的ashx,一个接收的ashx
上传文件代码
[csharp] view plain copy
  1. public void ProcessRequest(HttpContext context)
  2.         {
  3.             //参考http://www.cnblogs.com/greenerycn/archive/2010/05/15/csharp_http_post.html
  4.             string filePath = "d:\\apple4.jpg";
  5.             string fileName = "apple4.jpg";
  6.             string postURL = "http://192.168.1.11/testhandler/accfile.ashx";
  7.
  8.             // 边界符
  9.             var boundary = "---------------" + DateTime.Now.Ticks.ToString("x");
  10.             var beginBoundary = Encoding.ASCII.GetBytes("--" + boundary + "\r\n");
  11.             var fileStream = new FileStream(filePath, FileMode.Open, FileAccess.Read);
  12.
  13.             // 最后的结束符
  14.             var endBoundary = Encoding.ASCII.GetBytes("--" + boundary + "--\r\n");
  15.
  16.             // 文件参数头
  17.             const string filePartHeader =
  18.                 "Content-Disposition: form-data; name=\"{0}\"; filename=\"{1}\"\r\n" +
  19.                  "Content-Type: application/octet-stream\r\n\r\n";
  20.             var fileHeader = string.Format(filePartHeader, "file", fileName);
  21.             var fileHeaderBytes = Encoding.UTF8.GetBytes(fileHeader);
  22.
  23.             // 开始拼数据
  24.             var memStream = new MemoryStream();
  25.             memStream.Write(beginBoundary, 0, beginBoundary.Length);
  26.
  27.             // 文件数据
  28.             memStream.Write(fileHeaderBytes, 0, fileHeaderBytes.Length);
  29.             var buffer = new byte[1024];
  30.             int bytesRead; // =0
  31.             while ((bytesRead = fileStream.Read(buffer, 0, buffer.Length)) != 0)
  32.             {
  33.                 memStream.Write(buffer, 0, bytesRead);
  34.             }
  35.             fileStream.Close();
  36.
  37.             // Key-Value数据
  38.             var stringKeyHeader = "\r\n--" + boundary +
  39.                                    "\r\nContent-Disposition: form-data; name=\"{0}\"" +
  40.                                    "\r\n\r\n{1}\r\n";
  41.
  42.             Dictionary<string, string> stringDict = new Dictionary<string, string>();
  43.             stringDict.Add("len", "500");
  44.             stringDict.Add("wid", "300");
  45.             foreach (byte[] formitembytes in from string key in stringDict.Keys
  46.                                              select string.Format(stringKeyHeader, key, stringDict[key])
  47.                                                  into formitem
  48.                                                  select Encoding.UTF8.GetBytes(formitem))
  49.             {
  50.                 memStream.Write(formitembytes, 0, formitembytes.Length);
  51.             }
  52.
  53.             // 写入最后的结束边界符
  54.             memStream.Write(endBoundary, 0, endBoundary.Length);
  55.
  56.             //倒腾到tempBuffer?
  57.             memStream.Position = 0;
  58.             var tempBuffer = new byte[memStream.Length];
  59.             memStream.Read(tempBuffer, 0, tempBuffer.Length);
  60.             memStream.Close();
  61.
  62.             // 创建webRequest并设置属性
  63.             var webRequest = (HttpWebRequest)WebRequest.Create(postURL);
  64.             webRequest.Method = "POST";
  65.             webRequest.Timeout = 100000;
  66.             webRequest.ContentType = "multipart/form-data; boundary=" + boundary;
  67.             webRequest.ContentLength = tempBuffer.Length;
  68.
  69.             var requestStream = webRequest.GetRequestStream();
  70.             requestStream.Write(tempBuffer, 0, tempBuffer.Length);
  71.             requestStream.Close();
  72.
  73.             var httpWebResponse = (HttpWebResponse)webRequest.GetResponse();
  74.             string responseContent;
  75.             using (var httpStreamReader = new StreamReader(httpWebResponse.GetResponseStream(),Encoding.GetEncoding("utf-8")))
  76.             {
  77.                 responseContent = httpStreamReader.ReadToEnd();
  78.             }
  79.
  80.             httpWebResponse.Close();
  81.             webRequest.Abort();
  82.
  83.             context.Response.ContentType = "text/plain";
  84.             context.Response.Write(responseContent);
  85.         }
接收文件
  2.         {
  4.             if (context.Request.Files.Count == 0)
  5.             {
  6.                 context.Response.Write("No file");
  7.                 return;
  8.             }
  9.
  10.             HttpPostedFile f1 = context.Request.Files[0];
  11.             System.Drawing.Image image = System.Drawing.Image.FromStream(f1.InputStream);
  12.             image.Save("d:\\upload.jpg");
  13.
  14.             string strPars="";
  15.             foreach (var key in context.Request.Form.AllKeys)
  16.             {
  17.                 string val = context.Request[key];
  18.                 strPars += "["+key + ":" + val + "] ";
  19.             }
  20.
  21.             image.Dispose();
  22.             context.Response.Write("OK Get File:" + f1.FileName + " Pars:" + strPars);
  23.         }
该文章在 2017/3/22 0:30:22 编辑过
